Installed a new tach side gear, started the engine and the tach started working and then quit. I think I remember someone saying that you might need to add another washer between the coupler and the side gear when you install another one. Is this right? ANy suggestions? Thanks
C3 Tach Side Gear
Re: C3 Tach Side Gear
Generally, when the tach gear is broken, it takes the gear on the distributor shaft with it and they need to be replaced as a set. Usually the housing will need some repair at this time also to prevent the problem from recurring.Bill Clupper #618- Top
The tach cable could be at fault. Disconnect the tach cable from the distributor and if you have a piece of an old speedometer cable you could insert a end piece of it into the tack drive and start he car and verify your gear is turning. The end of a tack drive cable could become out of shape and not turn with the tach gear. You could use a electic drill on the disonnected tach cable and test out the tach. You mentioned installing a new tach side gear. If this was done because the old tach side gear was damaged the distributor shaft would most likely need replacement as well.- Top
