I have a small coolant leak at the rear of the engine, I have the whole rear suspension, rear end and transmission out for rebuild, clean paint etc. I pulled the flywheel hoping to find a freeze out plug leak. The freeze plugs look very clean and dry and I can't find any signs of a leak. The cam plug looks old and dirty but that would be oil not coolant. There are three allen head set screws in the back of the block, do these enter the oil passage or the water jacket, and what are they for? Do you have any ideas where this cololant may be coming from. I don't know where else to check, and starting the engine to let it warm out is not easy at this point.
Thanks in advance,
George
#36908
Thanks in advance,
George
#36908
