Inspection checklist for buying a C2 or C3? - NCRS Discussion Boards
  • Bill #36445
    Would anybody happen to have a checklist of things to check or look out for on an initial inspection of a Midyear or Pre-73 Mako? Im looking to purchase a classic Corvette but I'm not sure of all the areas that I should be aware of or the telltale signs that say "Stay Away". Your help, as always, would be greatly appreciated.
  • Michael H.
    • July 31, 1998
    • 180
    Re: Inspection checklist for buying a C2 or C3?
    Hey Bill -
    The single most common mistake people make is not getting the car up on lift and inspecting the frame and suspension. From underneath you can also get a good view of any major body repairs that have been done. If you e-mail me I can send you a checklist (mghaluska@aol.com), but the deal breakers are things like a bent frame or severely corroded kick-up area.
    If there is someone in your Corvette Club or a technician familiar with Corvettes, pay the guy $100 and have him give you an assessment. Unless the car has been recently restored, you can almost bet that the suspension needs a complete rebuild. And if you're going to start replacing bushings, you may as well replace ball joints, tie-rod ends, bearings, u-joints, seals, etc since you have already paid to have the major components (control arms, trailing arms) removed. These repairs can easily run into $8,000 or more when all is said and done.
      • 15573
      Not so far away is an on-line check list. THe explanation and original link were in the Winter 2004 edition of The Corvette Restorer. One of the benefits of NCRS membership.
      Buying Your Next Corvette
      • William C.
        • May 31, 1975
        • 6037
        The scoring sheets from the Judging system also can be used to provide a comprehensive checklist
        Bill Clupper #618
