The code on my 78 differential reads "OK 311 W 7E 1" My interpretation of the code indicates a 3:08 assembled the 311 day (November) by the Warren Motive Plant. Positraction is by Eaton and the first shift. I realize the W in early years came before the date code but I'm also curious about the "7E" Suggestions?
C3 Late Model Axle Code
Tags: None
Re: C3 Late Model Axle Code
Tom,
The "7"-is the year 1977 I'm also not sure about the "E" maybe it stands for Eaton Positraction unit. Just a guess about the "E"
Attached Files- Top
E means Eaton Posi., I think.
while the W= Warren, MI Plant
but
W could also mean "Warner Motive Posi." if used in place of the E.http://MichiganNCRS.org
Michigan Chapter
Tom Dingman- Top
Eaton Posi units were used in all Corvette diffs from '65-'79, and Dana units were used from '80-'82.- Top
Well the "W" refers to the Warren differential assembly plant while the E refers to the Eaton "postitraction" supplier. The 7 most reasonably seems to refer to the production year for the posi...1977 as Vito suggests.
It seems there were three different axle code sequence configurations used between 1968 through 1982. The first covered 68-69 and perhaps earlier, the second the mid-years (70-77) and the third 78-82.Tom Russo
78 SA NCRS 5 Star Bowtie78 Pace Car L82 M2100 MY/TR/Conv- Top
