Big block oil consumption
  • Jim Munger (10441)
    • September 1, 1986
    • 50
    Big block owners experiencing excessive oil consumption and plug fouling with little or no blue smoke out the exhaust will appreciate the following tip. Assuming your rings/bores, valve stems/guides, and intake seal are up to par, get yourself a set of Enginetech brand umbrella type valve stem seals. You will not be disappointed with the results. They are DEFINITELY worth looking for. Do a web search for "Enginetech" and you will be able to find a list of their local distributors.
  • Wayne Womble (5569)
    • May 1, 1982
    • 3605
    Re: Big block oil consumption
    I used DEPENDS they work well.
      • September 1, 1986
      • 50
      Funny, but I thought this forum was for the sharing of technical information about the Corvette. Oh well. Jim #10441
        • May 1, 1982
        • 3605
        Sorry, just having a little fun with ya. But, assuming your rings/bore, valve stems/guides and seals are up to par, you should not need the Enginetech seals.
