Re: How to cut fiber optic cable?
Thad,
It seems like you have had a lot of opinions on repairing fiber optics. I too had a problem with the fiber cable leading to my left front turn signal on my '69. My cable was broken and the end was shreaded so it needed to be cut and I had to splice a new piece to complete the run to the turn signal. I also was missing the rubber connector that attaches the cable to the nipple on the side of the turn signal housing.
I guess I wasn't bright enough to know that the cable could not be repaired so I purchased one of those repair kits that you will find in most of the Corvette catalogues. I needed the repair kit primarily for the additional length of cabling to complete the splice. I cut the old frayed cable with Craftmans Handi-Cut cutters and they made a pretty clean cut on the fiber (by the way these cutters work great on heater and vacuum hoses also). My next concern was how to attach the cable to the turn signal housing without the original connector. I was talking to a friend of mine (who also posts on this board as well) and he asked me if I thought one of the rubber vacuum caps (bullet shaped) would work. I thought it would be worth a try so he went into his tool box and pulled out a number of different color and size caps. The one that looked about right happened to be black but was a little long. He gave that to me and I brought it home to see if it would work. I had to trim about 3/8 of an inch off the end and it fit right over the nipple on the housing. It looks almost identical to the original connector. I took an awl and punched a hole in the closed end so that the cable would pass through it. It slipped right over the nipple perfectly.
Now I was down to figuring out exactly how to splice the two cable ends. Another friend in the communications business gave me a piece of wet sand paper to polish the ends of the cable. This stuff was really fine grit. When you pass your hand across it the paper feels smooth. I wet the paper and rubbed both ends and I am sure that this probably helped but to be honest these 51 year old eyes had a very difficult time seeing whether this made a difference. I was now ready to butt splice the two cables but I was just not comfortable with using shrink tubing and then taping over top of the repair (which is what the repair kit tells you to do). Since this was going to be a butt splice I had a difficult time convincing myself that over time the shrink tubing and tape would maintain the integrity of the original repair. So, another friend who works at a machine shop took a small piece of the fiber cable with him to work and made me a small round (tube shaped) aluminum ferrule about an inch and a half long. He drilled a hole through the entire length of the ferrule so that the cable would just barely fit through it. I then took the new piece of cable that was now attached to the turn signal and inserted it into one end of the ferrule. I took the other end that I had repaired and slid it into the other end of the ferrule. I then wrapped some tape around the ferrule so that I could test the light passage to the console. It worked pretty well. I then went back to the aluminum ferrule and just barely crimped each end so that I had a snug fit and the cable could not pull out of it. Be careful crimping this cable, you just want to put pressure on the insulation and not damage the fiber. Then I wrapped the entire repair with electrical tape and the repair is not noticeable to the naked "judges" eye. After owning this car for 11 years all of the optics work on the console.
This may sound like a lot of work but it really wasn't that bad. Plus it was a lot cheaper than a new wiring harness. Good luck with yours!
Thad,
