70 vette - NCRS Discussion Boards
70 vette
  • Dean33398
    70 vette
    does any one know any thing about a TCS, transmission controlled spark on a 70 vette ? Thanks in advance. Dean
  • Tony H.
    • May 31, 1993
    • 537
    Re: 70 vette
    Dean----
    Yes, quite a few people who frequent this site do know about the 1970 TCS. You need to be a bit more specific about what it though. Ask away.
    Tony
    • Jim T.
      • March 1, 1993
      • 5351
      Re: 70 vette
      I disconnected my TCS on my 70 not very long after I took delivery back on August 18,1970. It is still disconnected. The advantage for me of having it disabled is better gas mileage in city type driving. Basically, the TCS prevented vacuum to the distributor vacuum advance on the turbo 400 70's in low and second. When the transmission shifted to third you would have vacuum to the distrubutor vacuum advance. With the TCS disconnected I connected a vacuum line from the distributor vacuum advance to full time vacuum, not ported vacuum on the carb.
      • Dean33398
        Re: 70 vette
        Does anyone have a schematic on the tcs system, on the 70 vette?, We would like to look at one.Thanks again, Dean
        • Roberto L.
          • January 1, 1998
          • 523
          Re: 70 vette
          Hello, will try to help a bit more. TCS controls vac advance sensing two variables, engine temperature and gear position. There is a trans switch in 3rd/4th lever, a temperature switch in RH (SB) cylinder head (different from ordinary LH switch), a solenoid at RH of carburator and a relay. Solenoid connect/disconnect vac advance depending on temperature and gear.
          Harness derivation with connector (green wire) goes to RH temp switch, black wire goes to trans switch (if I'm correct), flat connector goes to solenoid in forward position (70 vette).
          Temp switch senses very low and very high temperatures (start up and very warm condition).
          Roberto, NCRS #30019, RMC
          • Tony H.
            • May 31, 1993
            • 537
            Re: 70 vette
            Dean,
            Try Doc Rebuild's website to see if you can get the image of the TCS for your model year and engine option. You can find it under A-Z: H: Hoses, Spark Control.
            Doc's catalog is one of the best around!
            We manufacture and distribute original style 1953 through 1982 Corvette reproduction parts. We also stock many Original, OEM and NOS parts. This is our 26th year as a brick and mortar business supplying C1, C2, C3 Corvette parts exclusively. 200 page paper catalog with 1000+ illustrations $4.00
            Tony
