I am trying to remove the rear shock mount using PB Blaster to soak it free.I also bought a 4 inch knocker that threads onto the threaded end of the mount.Giving it a few blows still no luck.Tryed relieving some tension with a jack under the spindle ears.Do not want to use a torch due to rear gas tank and weakening the steel ears and mount.Is it any easier to reinstall the shock mount? Extremely tight fit.
I want to change out strut rods 1 at a time.Does the Strut rod bracket and its 4 bolts holding it to the Differential need to be removed?It appears that removing the cam bolt nut and washers the rod will be able to come out once the rod is removed from the ears.
Greg
Greg
