Hi all,
Next week my correctly casted engine (230hp) will arrive from the States and I'll send it to the revision company to make sure it is in 100% condition when I'm going to drop it in the car in October. I wonder what items I should point out to the engine revision company to do (obviously they will have quite a good idee what should happen but I just want to be sure I don't forget anything):
* Put in hardened valve seats for unleaded fuel usage
* Inpect and, if needed, enlarge the cylinders
* Replace all bearings
* Replace chain
* Replace valves
* Replace clutch plates
Others things ?
thanks (again) for your suggestions,
greetings,
Rob Musquetier.
The C1 '59 restoration project
* Replace chain
* Replace valves
Others things ?
greetings,
Rob Musquetier.
