I am restoring a '54 and would like to put radial tires on it for better handling. I will use bias ply tires for show. Coker tire says the replacement is a 205R75X15 but has a slightly smaller outside diameter than the original 6.70X15. They also said that the 215R75X15 would have an outer diameter closer to the original but is wider and may cause rubbing on the body. Does anybody have experience in using the 215 and does it clear the body. Thanks.
Bob Valeski
Huntington Beach, CA
Bob Valeski
