C1 Gas tank cover holdown screws - NCRS Discussion Boards
  • Joe Maulsby
    There are 18 screws that hold the gas tank cover in place on my 1960. The front nine screws thread into captive nuts, the 7 rear screws thread into J-nuts and the 2 side screws thread directly into the fiberglass. My front 9 screws are the same size and length and they are made out of aluminum. Are aluminum screws correct? If not, what size screws are correct?
    What size should the side and rear screws be? The screws I removed are several sizes and a mixture of phillips and straight head screws; obviously not original or correct.
  • Dennis A.
    • April 30, 1999
    • 1010
    Re: C1 Gas tank cover holdown screws
    Joe...
    The threaded screws are not aluminum. Best way to deal with this is to order a gas tank cover screw set for about $12 bucks, including the correct "J" nuts. 56-E61 screws are different from L61-62. Be sure and specify.
