'65 Power Brakes - NCRS Discussion Boards
'65 Power Brakes
  • Jeremy Hedges
    '65 Power Brakes
    I am just getting this car back together, working out the bugs. The brakes seem to build up pressure when the car gets hot. The hotter the temperature the more pressure on the brakes. It is a power brake car with the original booster and master cylinder which have both been rebuilt. What could be the problem? When the car cools down the brakes are fine.
    Jeremy Hedges
    #31711
    Re: '65 Power Brakes
    Jeremy -
    Do you have the clevis adjusted where the booster rod connects to the pedal so you have the specified pedal free play? If you don't have pedal free play, the power valve in the booster can be partially activated and apply brake pressure.
