C1 Shifter Questions - NCRS Discussion Boards
  • Ted S.
    • January 1, 1998
    • 747
    Can someone out there tell me the diameter of the holes in the clevises that connect to the transmission shift arms, the diameter of the mating holes on the shift arms, and the diameter of the pins that fit through the holes? I bought a shifter with linkage and I believe the holes in the clevises have been enlarged or else the transmission arms aren't correct. The clevis holes are much larger than the pins and the arm holes. Thanks Ted
    Re: C1 Shifter Questions
    Ted -
    Print specs show the hole in the clevis is .312"-.314", and the hole in the lever is .313"-.317"; don't have the print for the pin.
    • Ted S.
      • January 1, 1998
      • 747
      Thanks John - Shifter Clevises were Bubba-ized *NM*
