C1 Carburetor ID Tag - NCRS Discussion Boards
  • Bob Hardy
    I'd sure appreciate a bit of advice from one of you gurus. The triangular alminum tag used on the '61 Carter carbs (and others) had a date stamped in the 4 dividers at the lower edge of the tag. Problem is - the date stamp needs only 3 spaces. My carb was built in May of 61 by assembly line #3. My question is this: in what order are the alphanumerics stamped on the pad? for example, E13blank, or woulde it be blankE13? Also, what are the size of the letters/numbers? Just trying to get all the t's crossed correctly. Thanks - Bob
