I am working on a '62. Where on the instrument cluster is the ground wire attatched? Where exactly is the amp capacitor attatched? I have an issue with this car where the two above questions might be an issue. The fuel gage right now reads 1/2 a tank (which is correct) but whenever the headlights, brakelights, or blinkers are on the fuel gauge reads full tank. The gauges all work like they are supposed to otherwise. Turn signal lights work. I would think that if the ground was not right, nothing would work. Right now the ground is attatched to the housing for the speedo, where I thought I took it off of. Any advise would be helpfull.
Jeremy Hedges
#31711
Jeremy Hedges
#31711
