Re: Jerry: Exchange faster / Better?
Tom, I have to agree with Jerry that more flow rate yields better cooling. I am an engineer and occasionally run into cooling problems on our compressor engines and gas plant heat exchangers. Although I did not pay much attention in my Thermodynamic class, I have re-educated myself enough over the years in order understand my work related purchases. I try to get things explained to me in "bubba-speak" so that I don't have to thouroughly understand all of the equations. Here is my attempt... When you think about it there are two heat exchangers on the cooling system. The engine rejects heat to the cooling water via passages in the block and the radiator rejects coolant water heat to the air. There are two sides to the radiator and the flow rate on either side of the tubes regulates the heat transfer. If you slow down the air movement, you will reduce the amount of heat that is carried away from the radiator. For some reason we are all willing to agree that more air flow at the radiator will cool the water and the engine. The same is true of an air cooled engine. The water cooled engine is no different than the air cooled engine. In order to carry away more heat from an air cooled engine, you circulate more cooling air past the engine or compensate for lower air flow or higher air temp by adding larger cooling fins. To cool the water cooled engine, circulate more water. Why wouldn't more water flow at the engine cool the engine? Higher fluid velocities also increase heat transfer by reducing the fluid film thickness on the tubes. The higher velocity also helps keep the tube clean of scale and dirt buildup.
Some prior postings suggest to decrease the coolant circulation rate so that the water picks up more engine heat in order to maximize the temp differential at the radiator. There has also been mention that the slower rate will give the water more time to cool in the radiator. It is true that the temperature differential is a driving force similar to voltage in an electrical circuit. When the coolant rate is slowed down more heat is added to a unit volume of water via conduction. At the same time, the lower flow rate reduces the heat that is transferred from the block by convection. The heat transferred from the engine to the radiator is a function of the flow rate of the coolant. And is the dominant transfer mechanism. The purpose of the cooling system is to carry heat away from the engine and that cannot be done at lower circulation rates that rely more on conduction as opposed to convection. Technically it is the log mean temperature difference (LMTD) that is used for sizing heat exchangers and we are dealing with two exchangers. The water is the cooling media at the engine block but at the radiator the air is the cooling media. The way the LMTD formula works, the water is the cold fluid at the engine and at the radiator it is the hot fluid. The increased temp differential at the block appears in a different spot in the formula when calculating the LMTD at the radiator. Basically it helps move more heat in one case and decreases heat transfer in the other case. Heat exchangers are always a compromise. There is no substitute for surface area. However larger coolers are more expensive, heavier and increase the frontal area of the vehicle. Higher coolant circulation rates increase the friction which can lead to cavitation. Higher pressure requires more pump horsepower and thicker tubes to contain the coolant which translates into heavier less efficient radiators. Then you are back to increasing cooler size I will end with this... If your engine already tends to overheat, does it make sense to add more heat to the coolant at the engine so that you will have to reject more heat at the radiator?
P.S. I was under the impression that coolant restrictors limited flow to the radiator so that heat was retained in the engine. Higher temperatures lead to higher combustion pressures, efficiency and more power. However, durability decreases with temperature but that is not a huge factor with drag racers who regularly dismantle the engine.
