Lifting front of C1 - NCRS Discussion Boards
Lifting front of C1
  • Chris H.
    • April 30, 1990
    • 817
    Lifting front of C1
    Where do you lift the front of a C1 with a hydraulic jack?
    thanks, Chris
  • Mike M.
    • May 31, 1974
    • 8365
    Re: Lifting front of C1
    Avoid the third arm that pivots from the lower center of the front crossmember. they fracture easily if the c-1 is jacked off that point. get under the frame or the lower a-arms. mike
      Chris -
      I made up a simple "saddle" from a 6" length of 2x4 with two 2-1/2"-long pieces of 2x4 nailed to the top (1" gap in the center between the two short pieces) to jack the front of my '57; the third arm piece fit in the gap, and the outer pieces lifted on the frame crossmember.
      • Chris H.
        • April 30, 1990
        • 817
        Thanks John, I will make up one tonight.
        Chris
