59 water pump/engine mount - NCRS Discussion Boards
  • Robert D.
    • April 1, 2003
    • 305
    any one ever have a hard time sealing them together? any tricks? there is supposed to be a gasket in between the mount and block and the pump and mount correct? any help would be appreciated
    thanx
    bob
  • Dean Bailey
    Re: 59 water pump/engine mount
    Bob: Yes, 4 gaskets required. Use black RTV sealer (silicone)on all mating surfaces and on threads. Use lock washers and torque to spec. It's easier to handle the entire assembly if you temporaily install 3/8" pilot bolts (cut heads off extra 3" bolts to form a stud) in top two holes and slide gaskets, motor mount, gaskets, and water pump onto pilot bolts. Then install 2 lower bolts, remove pilot bolts, and install 2 upper bolts. Not too hard, but silicone can be messy.
