More on Tires - NCRS Discussion Boards
More on Tires
  • Roger Steele
    More on Tires
    Wanting an opinion on Goodrich Radial T/A in 215-70R-15-97S to be installed on a 65 convert. Thanks for your help
    • 15610
    Re: More on Tires
    "S" speed rating! No nylon cap belt! No way!!!
    There are several nylon cap belted "H" and "V" rated 215/70R-15s out there, and even though the Z-rated Pirelli P4000 Super Touring appears to be out of production in this size, there is still inventory out there.
    • Jerry G.
      • April 1, 1985
      • 1022
      Z rating vs WR
      I went to the tire rack site and don't find the Pirelli super touring in Z is the WR they show the same? Jerry
        • 15610
        Re: Z rating vs WR
        The basic Z-rating means the tire is capable of "over 149 MPH", however, this can be modified by either a W (168 MPH) or Y (186 MPH) in the service description following the size designation on the sidewall. The 215/70ZR-15 P4000 is modified with a W. Modern Corvette Z-rated tires are modified with a Y.
        Listing the tire as a 215/70WR-15 is a short hand way of listing the speed rating without listing the service description, but does not conform to industry standard nomeclature. If you look at the sidewall the size and service description will read:
        215/70ZR-15 99W
        • Jerry G.
          • April 1, 1985
          • 1022
          Your a wealth of info, thanks *NM*
          • Steve Pettit
            Re: Your a wealth of info, thanks
            Amen to that, and thanks Duke I received my p4000's today. Yeeha now for some alignment tweaking and then the N. california backroads.
            • roger steele
              Re: More on Tires
              Thanks for the info, you all are very helpful. I'm sure I'll have other questions in the future.
