Firewall insulation on 63 coupe - NCRS Discussion Boards
  • Rainer S.
    • May 31, 2003
    • 468
    I want to replace the firewall/sound deadener insulation on my early (Dec 62) 63 coupe.
    I had only the lower firewall insulation, not the upper dash sound deadener installed. Should I install both ? Will I loose points, If I do install the sound deadener anyway, will I loose pionts,when I will have the car judged ? Which supplier carries the best replacement ?
    Rainer
