1956 hole location for power window conduits - NCRS Discussion Boards
  • Bud Baker
    Re: 1956 hole location for power window conduits
    Bud -
    The size/shape/location of the conduit holes is shown in the A.I.M. in the RPO 426 Section, Sheet 2.00, View "B". The hole is a rectangle, 2.17" high x 1.39" wide, with 1/8" corner radii. Its location is shown on the sheet, relative to the hinge holes.
    • Dennis C.
      NCRS Past Judging Chairman
      • January 1, 1984
      • 2409
      Sounds like you are adding PW...
      I will not comment on that issue, but if that is your choice, I would seek out an owner of an original PW car and see if that owner is willing to share the typical factory cutout for the conduit - and maybe even what was written on the inside of the PW door. Best, Dennis
      • Roy B.
        • February 1, 1975
        • 7044
        55 to 57 Chevy Nomad and Safari power window assy., switches, door wire guides, motors and wire harness is the same as Corvette. plus door hinges out side handle and more
        • Mike M.
          • May 31, 1974
          • 8365
          Roy: would the chevy 150, 210 and bel-air, as well as the non-safari pontiacs have the same power window parts as vet or just the top of the line chev and pontys? mike
          • Roy B.
            • February 1, 1975
            • 7044
            Mike only the 55 to 57 Nomads and Ponty Nomad. It's the door size that makes it so.
