C-2 Undercoating - NCRS Discussion Boards
C-2 Undercoating
  • Jim Carr member #35014
    C-2 Undercoating
    Can you recommend product and techniques to apply undercoating.
    Re: C-2 Undercoating
    Only undercoating used was in the wheel well area to thwart stone kickup from leaving bullseye in overhead fender paint. A can of off-the-shelf undercoat from your local auto parts store gets the job done.
    As far as coverage, it varied with the phase of the moon based on painter and his in-a-hurry attention to detail. I've seen some untouched originals with nothing more than a ragged 1-2 inch spritz in the center of the wheel well to others with VERY heavy coverage, runs & sags. This is an area of Corvette restoration that's pretty much an owner's choice 'art form'....
    • Ralph E.
      • February 1, 2002
      • 905
      Is it recommended to replace the old undercoating with new undercoating once the it has been removed?
      • Bryan L.
        • June 30, 1998
        • 397
        I think it's a good idea in the fender peaks. That's the only place I re-sprayed with u/c. I found some 3M that goes on kinda thick and looks good. I bought some cheaper stuff but it was pretty thin and messy.
        BL
