A previous owner of my '59 used clear silicone to attach some of the door rubber weatherstips. I would like to clean the silicone off the base clear paint. Any suggestions as to what could be used would be appreciated.
removing clear silicone
Re: removing clear silicone
i know of no solvent that will soften silicone without also playing hell with your paint. matter of fact, i know of no silicone solvent . I employ Mr Buck/Old Timer/Case/Barlow etc along with mr fingernail. tedious work. good luck, mike- Top
Pat------
Gasoline is a solvent that will degrade and soften silicone RTV (that's also the reason why you should NEVER use silicone RTV for any application that's exposed to gasoline). However, I like Byron's suggestion better.In Appreciation of John Hinckley- Top
DONT use the rubber wheels on fresh paint ! It works great on oem paint but not on repaints. I would try Mikes idea your finger nail or a plastic razor blade. You can also use dupont prep sol ,lacquer & enamal cleaner,3Ms adheasive remover,or my 1st choice dupont 3812 enamal reducer(be very careful with the 3812 it WILL soften & dull the paint). throw the weatherstrips away you will never get weatherstrip adheasive to stick.Bill- Top
I spent days removing lots of silicone from the windshield frame to body channel, trying all types of solvents, and even heat. Like Elliot Ness, that stuff is untouchable. Even tried a new Permatex product, SILICONE STRIPPER, but still no luck. Ended up carefully removing the bulk with a razor, but not down to the painted areas. From there, it was all left to the fingernail, as Mikey says. Luck to you, Dick.- Top
Hey all you fingernail scrapers! Get yourselves a few Lil' Chizlers. Great, hard plastic scraper that is the world's answer to busted fingernails. Safe on most surfaces too. Try Signs Plus Banners at 800-635-6897. Bag of 10 - 5.99; bag of 25 - 12.99
No kickbacks or connections, just one of the best prices I've found.
Dave ZDave Zuberer- Top
