C2 - NCRS Discussion Boards
C2
  • Ken Root
    C2
    We just finished a body off restoration on a 1963 corvette. During the process we replaced all of the wiring and the gauges were redone. Our problem is, the fuel/battery/temperature gauges don't work. Everything else electrical on the car is working fine. The ground wire is connected to the back of the cluster. Is it possible I still might be having a ground problem or something else that we're missing? Any feedback would be greatly appreciated.
  • Joe R.
    • July 31, 1976
    • 4547
    Re: C2
    Ken,
    Check the instrument cluster for the lights. If they illuminate the ground is OK. Check and see if the fuse is blown or 12V present at the gauges.
    Hope this helps,
    JR
    • Harry Sadlock
      Re: C2
      Ken, have you found the problem? I'm getting ready to put my 63 cluster in and I would like to know what you found.
      Harry
