Re: valve cover cap screw torque - NCRS Discussion Boards
  • Pete Ruegg
    Hi All,
    What is the aluminum valve cover cap screw torque on my 327?
    Pete-----
    It's variously reported in the range of 25 lb/inches to 55 lb/inches. I use 55 lb/INCHES. That STILL won't feel like it's tight enough, but it's tight enough. Use more and it could get expensive. Remember, this is lb/INCHES; it's NOT lb/FEET.
    • Pete Ruegg
      Thanks Joe,
      I'll remember that it AIN'T foot lbs but 25 to 55 inch lbs. I'll torque them to 55 in.lbs the same as you have ...Pete
      • Charles M.
        • March 1, 2002
        • 155
        How can that be converted to lbs/feet? Simply divide by 12 or what?
        • Charles M.
          • March 1, 2002
          • 155
          I found this at "Ask Jeeves".
          (quote)
          A lb/ft of torque is the amount of leverage exerted by a one-pound weight hung at the end of a one-foot lever extending out at 90 degrees from the point of attachment. That is the same as two pounds hung on a six-inch lever (half a foot & twice the weight, you know?), or a half-pound hung on a two-foot lever. If the pull is exerted at less than 90 degrees the torque is correspondingly less.
          An lb/in of torque is a one-pound weight hung on a 1-inch lever. Lb/inches are used to express small amounts of torque. You can convert directly by using a factor of twelve. 10 lbs/ft of torque is 120 lb/inches. 96 lb/inches is eight lbs/ft, etc.
          (end quote)
            Chuck------
            Divide by 12 is the simple answer. However, this is moot since, presumably, the reason that one would want to know the lb/feet equivalent is to use a lb/feet scale torque wrench to set the torque. ANY lb/feet scale torque wrench is going to be inaccurate in the torque range of 2-5 lb/feet (the approximate equivalent of 25-55 lb/inches). To accurately apply this sort of a torque value, you're going to need a LOW RANGE inch/pound torque wrench.
