'57 Horn bolts - NCRS Discussion Boards
'57 Horn bolts
  • Rex Kelly
    '57 Horn bolts
    Should the WB bolts that attach the horn brackets on a '57 be painted gloss black as the horns or left unpainted?....thanks
  • Roy B.
    • February 1, 1975
    • 7044
    Re: '57 Horn bolts
    Painted black
    • John P.
      1956-57 Team Leader
      • April 30, 1992
      • 63
      Re: '57 Horn bolts
      Rex, I believe I would expect to see them dark. peraps black phosphate or engine blackout. The horns themselves were dipped so the bolts wouldn't be painted glossy with them.
      • Mike E.
        • February 28, 1975
        • 5134
        Re: '57 Horn bolts
        Rex--
        I'll offer another opinion. They were not painted at the same time as the horns, nor were they on the car during the blackout process. I've generally found cad plate to be the case.
        • John P.
          1956-57 Team Leader
          • April 30, 1992
          • 63
          Re: '57 Horn bolts
          Mike, I tend to agree with your logic on this based on the assembly process, the question I have in my mind is this? Usually when a bolt like this shows, and the bottom bolt shows through the grill they seem to be blacked out so they don't stand out? Any thoughts?
