C-2 SB Headers - NCRS Discussion Boards
C-2 SB Headers
  • Jeremy Hedges
    C-2 SB Headers
    I am working on a '65 small block with side exhaust and the customer wants headers. Is there a source for direct bolt-up headers for side exhaust? Or should I just cut the side exhaust and have muffler shop put together?
    Jeremy Hedges
    #31711
  • Terry D.
    • May 31, 1987
    • 2690
    Re: C-2 SB Headers
    Check with Summit Racing or Jeg's, both catalogs are online. I know Stahl makes them but they are overpriced. If you can't find them online call them, they have access to more parts than shown in their catalogs.
    • Scott Marzahl
      Re: C-2 SB Headers
      Headman makes a set to be used with the side exhaust. You will need to cut the side exhaust pipes and weld on the collector to bolt up.
        Re: C-2 SB Headers
        Here are the Hedman headers that will work (with minor surgery) - I used them on my tube-frame Grand Sport. In 1995, they were Hedman #68280.
        • Frank H.
          • May 22, 2013
          • 148
          Re: C-2 SB Headers
          I've seen the block hugger headers used with sidepipes as well as undercar exhaust,you can get them painted or in chrome for under 100 bucks.Last car I saw them on had 3" tubes going back with flanges for the sidepipes and three bolt flanges and caps to open the exhaust up when he wanted.
          • Craig S.
            • June 30, 1997
            • 2471
            Hey John, is that radiator support....
            NOS or repro.... Craig
