1965 Power Brake Lines - NCRS Discussion Boards
  • John Dillman #25965
    Because I like the safety of the dual circuit system, I am going to convert the '65 to original style (J-50, I think) power brakes.
    I emptied the bank account and got the master, which appears to be setup for
    3/16 lines. I dug through the sofa and the seats in all the other cars and
    found enough change to get new lines, the rear of which will fit the master,
    but the new front line (M/C to block at left front wheel) appears to be a
    larger, maybe 1/4" line. . . . I expected the front and rear lines to be the
    same size. . .. Correct? The AIM was not particularly helpful and the
    pictures in Noland's book were a bit confusing, too. Any thoughts? I think
    they sent me a '66 power brake front line, which would account for the larger
    diameter tubing . . . I believe the '65s had 3/16 all around, and the '66s
    (and, maybe, really late '65s) had 1/4 all around. . . .
    Also, the trailing arm lines do not have spring type armor, which I thought
    they should. Correct?
    Last week the people at inlinetube told me it is all perfect, and all is well
    in the world . . . but then stopped returning my calls . . . .
    John Dillman
    '65, '56, '35 house that keeps me from getting to the other two . . .
  • William C.
    • May 31, 1975
    • 6037
    Re: 1965 Power Brake Lines
    front and rear lines on a '65 are the same size, armor on the rear is standard, PB or not
    Bill Clupper #618
