C2 Oil Pan Restoration - NCRS Discussion Boards
  • Scott Landis
    Can anyone recommend someone (hopefully on the West Coast) to restore a 327/350 C2 Oil Pan that has had a rod go through the side? I would like to save it if possible.
    Thanks in advance - #32911
  • Jean C.
    • June 30, 2003
    • 688
    Scott,
    Although your note did not state the extent of the damage, I would think a good welder could patch the hole or rip in the pan. You should be able to find a local shop to do this.
    Best regards,
    Charlie
