'67 STARTER MOTOR/BENDIX REPLACEMENT - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    After sliding the bendix on, there is a retainer and snap ring to install. If I put the retainer on first and then the snap ring, the ring is not tight in the groove. It appears that the retainer compresses the ring, holding it tight in the groove. If I put the ring in the retainer and then try to install it, they separate during installation. How do I install these pieces correctly?
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: '67 STARTER MOTOR/BENDIX REPLACEMENT
    You put it on over the grove and push it into the retainer.
    • Rob A.
      • December 1, 1991
      • 2126
      I got it, kind of a strange arrangement, thanks...
