I am in the process of replacing the battery in my 1963. I have discovered that the battery cables have been replaced with the standard clamp type cables. I am considering replacing them with the correct reproduction Spring Ring type cables. Are these cables reliable and do they provide adequate terminal connection? Would you recommend the reproduction batteries? What are the appropriate battery specs (cold cranking amps, etc)?
Thanks, Jeff
Thanks, Jeff
