Wonderbar Antenna - NCRS Discussion Boards
Wonderbar Antenna
  • Peter Ansted
    Wonderbar Antenna
    I just installed the original AM radio in my '63 and it picks up 2 stations in this medium sized city. While the radio was on, I grabbed the antenna to extend it and the radio volume tripled and there was dramatically improved reception. Back to a weak signal when I was not touching it. All of the antenna hardware is in place, such as the ground strap and the plane. I never did replace ground straps in the engine or exhaust. Will completing the ground circuit help? Thanks.
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12695
    Re: Wonderbar Antenna
    Hi Peter,
    I would doubt this would make much of a difference for the level of reception. It would help a bit more for against the static though. Your engine is already attached to the frame via the mounting point at your gearbox so electrically there is already a connection made.
    When you grab the antenna your body becomes a part of the antenna (you are conducting electricity pretty well). I believe I've read in previous postings that you can enhance the reception a slightly by tuning the radio/antenna combination with a insulated screwdriver (preferably completely of plastic) on the back of the radio. When you do this make sure your antenna is completely extended.
    greetings,
    Rob Musquetier
    Bsc Electronics
    Rob.
    NCRS Software Developer
    • Harry Sadlock
      Peter, the AM adjustment screw on a 63 is on the right side of the radio. You need to remove the right side interior radio panel to access the screw.
      Harry
