67 aluminum steering hub - NCRS Discussion Boards
  • Justin N.
    • February 1, 2004
    • 318
    Dear Members,
    What's the best way to remove #3900579 from the steering shaft? I have undone the 3/4" nut and Flat washer. Do I need a pulley puller? I don't want to scratch the lower collar. It looks as though it pulls straight out off of the threaded shaft. I need to also access the turn signal lever to clean up. Thank you much!
    Justin #41362
    Re: 67 aluminum steering hub
    All you need is a steering wheel puller - any auto parts store will have them.
    • Jim T.
      • March 1, 1993
      • 5351
      Auto Zone should have one in their "loan a tool" program.
      • Jace H.
        • April 1, 1997
        • 253
        Justin,
        Good luck! I had to remove mine due to the turn signal lever being broken. I had a heck of a time getting mine off. I went through two pullers (bolts bent under pressure)and finally had to cut it off. Probably an extreme situation but mine was stuck. Not corroded but just plane stuck.
        Jace Holt
