67 "headlights" switch - NCRS Discussion Boards
  • Justin N.
    • February 1, 2004
    • 318
    Dear Members,
    I have unplugged and removed the switch from underneath the dash. I can see that Bubba's little, monkeyboy-nephew, Chaka has drilled two holes in the back of #5716351(switch). I took it apart to clean, inspect and reassemble. Does the pin that goes through the button need and type of lubrication? Should I try to clean contact tabs with high # grit paper for better electrical conductivity? Thank you much!
    Justin #41362
  • Rob A.
    • December 1, 1991
    • 2126
    Re: 67 "headlights" switch
    Definately clean the contacts, you'll find you don't have to put so much pressure on the switch afterwards.
    • Brian McHale
      I thought that P/N 1995149 was the headlight used in 1967 Corvette's, with 1995179 being a re-placemnt P/N.
      • Robert C.
        • December 1, 1993
        • 1153
        Replace it!
        • Justin N.
          • February 1, 2004
          • 318
          Dear Members,
          Thanks for the input! I'll give it a good cleaning and try afterwards for functionality. I'd like to do this first before the costly replacement.
          Justin #41362
