As some have seen in previous posts I have just rebuilt, resealed, cleaned and repainted everything on my 65 roadster from the flywheel back. I did the front end last year. I had the clutch plate rebuilt, the disc religned, and the flywheel resurfaced, as well as replacing the throwout bearing. First I must say the clutch worked perfectly before I took it out, but you know while you have the transmission out why not... I now have about 3 inches of free peddle, and haven't touched the adjustment, in fact I am about to the end of the rod and have no adjustment left to lengthen it. The new throwout bearing is the same length as the old and I am about out of ideas. I have removed the clutch fork boot and all seems to be assembled correctly in there. I have not tried to drive it yet to see if the clutch will disengage, that comes tomorrow. Anybody have any ideas, I can't believe a few thousanth's shaved off the flywheel and pressure plate could make that big a difference?
Thank you,
George
Thank you,
George
