Folks,
Stopped by Tony's Corvette this AM and got the rest of the story!
Not only were the lamps spliced into the old harness, but where the ACTIVATION SWITCH mounts into the door jamb area, well the hole is not the correct size! So, if this car came with courtesy lites from the factory, they DID NOT USE the standard activation switch!
From my research, the activation switch is the same part number, same size, etc. for 1963-1982 (or around those years anyhow). The hole to mount this switch in needs to be 3/8 inch in diameter, according to specifications! Well, the hole that is the door jamb is roughly 5/16 inch and the switch WILL NOT MOUNT without drilling!
Need folks thoughts before I start drilling the hole out! I still don't think this car came with the courtesy lites and they were added when the original owner took the car to Europe.
