I took my 66 Coupe to a local alignment shop in the hopes of setting up the front end the way I've seen discussed by Duke and others in various posts (i.e. 1 to 2 degrees of caster, 0 to 1 degree neg camber and 1/16th in. of toe). The tecnician is someone I know and trust and he was willing to spend the time with me to do this. All went pretty well, except that the maximum amount of caster we were able to achieve and leave some reasonable number of threads available on the back bolt was about 0.75 degree positive. We were able to retain a little negative camber, without any shimming on the front bolt.
Before we started the driver's side actually had a degree of so of negative caster.
Both sides now have about the same shimming (none in the front, and a bunch in the back--sorry that's not very scientific). The car drives straight and feels good. I'm not really worried about doing anything else to it. However, I'm just curious how one would get up to another degree of camber. At least on my car, this looks impossible.
