C1 shifter to trans bolt torque discrepancy? - NCRS Discussion Boards
  • Chris H.
    • April 30, 1990
    • 817
    I am bolting my shifter assembly to the 4 spd trans.
    Per section 685 sheet 1 of the AIM the torque should be 22-29
    Per sheet 2 it should be 11-16.
    Am I reading this right and is there an error in the AIM? What should it be?
    (the 3 spd shows 15-20.)
    thanks
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Of course, unable to give you an answer, but...
    ... believe I'd use new lock washers, blue Locktight and, I'm really not sure how you'd get a torque wrench on those babies. Course, I'm usually doing the tightening w/the tranny in the car. I'm just tickled to get a wrench on the stupid bolts. Don't overdo...
    • Chris H.
      • April 30, 1990
      • 817
      Re: Of course, unable to give you an answer, but..
      AIM shows NO washers of any kind?
      thanks
      • Dennis C.
        • January 1, 1984
        • 2409
        Chris, May I suggest in this case...
        ...you ignore the AIM and use lock washers. Actually, I find it hard to believe they weren't originaly used. Never played w/a C1 that wasn't so equipped and the normal mechanical assembly logic would call for them. Whatever. I will say, I've never received a judging deduction for those 3 washers or for the blue Locktite. Best, Dennis
        • Mike M.
          • May 31, 1974
          • 8365
          Re: Chris, May I suggest in this case...
          We WILL start checking this area of your next judging endeavor. mikie
          • Mike M.
            • May 31, 1974
            • 8365
            chris; do what dennis suggested. we won't check your c-1 for loctite or lock washers. mike
            • Dennis C.
              • January 1, 1984
              • 2409
              Gee whiz Mikie, I thought your kornputr crashed *NM*
              • Chris H.
                • April 30, 1990
                • 817
                If you look closely at the AIM it looks like there is an "indication" of a washer outline. However no arrow or part number shown.
                  The early A.I.M.'s weren't very descriptive, but this is a case of the 4-speed shifter attaching "same as production" (the 3-speed shifter); look in Section 7 and you'll see the shifter bolts and separate split lock washers - same parts were used on the 4-speed shifter.
                  • Dennis C.
                    • January 1, 1984
                    • 2409
                    John H. Thanks, I feel better already. DC *NM*
