54 Starter Relay? - NCRS Discussion Boards
54 Starter Relay?
  • Wayne P.
    • August 31, 1975
    • 1025
    54 Starter Relay?
    Anybody know what part number this thing is? Three connections, one coil.
  • Mike M.
    • May 31, 1974
    • 8365
    Re: 54 Starter Relay?
    do you mean the neutral saftey swich mounted on the firewall or the solenoid mounted on the starter motor?mike
      Wayne------
      The on-starter solenoid assembly was GM #1118135. The remote relay was GM #1116886.
      • Roy B.
        • February 1, 1975
        • 7044
        The neutral safty switch on the fire wall is vary rare to find and cost biga bucks if you locate one ( you know! being Corvette parts)BUT you can easly find the CAR over drive switch used on 55 to 57 Chevy cars that works the same as Corvette ,look is the same but for the one conecting arm location is pointing down ,where Corvette points to the right side. They go for about $45.00 well worth the cost to have with you in the Corvette if your's burns out.You cant read the part number any way on the original with out taking it off.( all C1's having PG are the same) I carry one, but that's me.
        • Wayne P.
          • August 31, 1975
          • 1025
          Which one? 1116903 or 1116886
          I'm looking for the firewall relay, not the solinoid, not the neutral safety switch.
          • Roy B.
            • February 1, 1975
            • 7044
            OK call it a relay
              Re: Which one? 1116903 or 1116886
              Wayne------
              GM #1116886 is the relay originally used. That relay was later replaced for SERVICE by relay GM #1116904. I don't know what GM #1116903 is; perhaps it's a usable passenger car relay. I'm sure that it's a later SERVICE piece, though, just like the 1116904.
