C1 Powerglide - NCRS Discussion Boards
C1 Powerglide
  • kenneth bingener NCRS#38563
    C1 Powerglide
    Can someone give the specs for the converter to flywheel bolts? Thanks, Ken
    1958 245hp
    Re: C1 Powerglide
    Ken-----
    The original bolts were of GM #3708352. These bolts are 3/8"-24 X 11/16" long. They are GM-300 material (SAE grade and they have a captured lockwasher. A captured lockwasher is not a necessity, though; you can use a seperate lockwasher. The length may be critical, however. You can easily trim/grind a 3/4" length bolt to the required length.
    No bolts of the original spec are currently available from GM.
