1971 Alarm Horn - NCRS Discussion Boards
1971 Alarm Horn
  • Gerard Q.
    • February 1, 2000
    • 284
    1971 Alarm Horn
    Here it is 5 days before the NJ regional meet and my alarm horn has decided to quit. When I tested it today it did sound once and then made a weak croaking sound and or clicking. The alarm relay is energizing it but I guess the diaphragm is bad? It's a long trumpet type mounted on the left rear fender. I've checked the usual sources with no luck. Any ideas where to get one.
    Thanks much for any help
  • lyndon Sharpton
    Re: 1971 Alarm Horn
    I dont know where you can get one that soon. some one can restore your horn. my 71 decided to lay down the other day also
    • Dick W.
      • 10483
      Re: 1971 Alarm Horn
      There is a remote chance that readjusting the horn will help you. the adjustment screw is located on top of the horn. Also, you might try using a good penetrating lube inside the horn. You will have to remove it and turn it upside down to accomplish this
      Dick Whittington
      • William C.
        • May 31, 1975
        • 6037
        Re: 1971 Alarm Horn
        Also check the ground between the horn and the frame. It grounds via the mounting and minor corrosion can cause no horn
        Bill Clupper #618
