battery tender
  • lyndon Sharpton
    #1
    battery tender
    I think my battery tender might be bad. I had it on for just a short time and when I felt it it was real hot. are those things susposed to be hot but this was like it was on fire! has anyone had this?
    • 42936
    Re: battery tender
    Lyndon-----
    It should not be more than warm to the touch. Is it charging continuously (i.e. the red light on all the time)? If so, there may be a problem with the battery or some other sort of significant current drain in the car.
    • Chuck R.
      • May 1, 1999
      • 1434
      Re: battery tender
      1) Bad battery cells causing excessive draw
      2) Low supply power to charger
      3) Wires crossed (been there done that)
      4) Bad unit as a result of #2
      5) Just a bad unit.
      Like Joe said, should be no more than warm to the touch. Theyre pretty straight forward Lyndon
      Chuck
      • Wayne K.
        • December 1, 1999
        • 1030
        Re: battery tender
        Lyndon,
        Try it on a known good battery/vehicle and see if it reacts the same.
