Tricks for getting out console plate? (62-340) - NCRS Discussion Boards
  • Rob Edwards
    I am going crazy trying to reattach the ground wire that connects to the back of the clock/heater control console plate in the '62. I even took the driver's seat out to get more space under the dash, no luck. I guess I'm a lousy contortionist! So how in heck do you get at this? Or is it easier to just pull the console trim and loosen the entire console fiberglass and do it that way? Any BTDT advise would be great. Thanks!
    -Rob
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: Tricks for getting out console plate? (62-340)
    No need to remove the fiberglass. Loosen the plate and work through the hole if you can't get behind it.
    • Rob M.
      NCRS IT Developer
      • January 1, 2004
      • 12695
      Rob,
      You might be able to pull the job using a magnatic screwdriver holding the tiny screw while you try to get it positioned right to get it in... Worked for me!
      greetings,
      Another Rob.
      Rob.
      NCRS Software Developer
      • Terry D.
        • May 31, 1987
        • 2690
        Try going in from passenger side. You have to remove fiberglass panel in front of heater, but way easier then from driver side.
        • Dennis A.
          • April 30, 1999
          • 1010
          Much easier from the passenger side...
