Hello all. I am gravity bleeding the brakes on my '69. I have done the rears (I think) and am wondering how you know when the caliper is completely bled. I have gone through about 3 reservoir fills of fluid for each bleeder. I never saw a single bubble pass through the clear plastic hose. In the past I have always used the pump/release method where you can plainly see the bubbles. I intend to follow up the gravity bleed with a vacuum bleed with a "Mity-vac" tool
Thanks for you help.
Jeff Salz
Jeff Salz
