Recently noticed that the filament on the high beams glow when the low beams are lit. Also, low beams seem quite hot, one new bulb is getting black.
Headlights/switch, dash headlight door switch, indicator/hi-beam lights on dash and dimmer all function as they should. New dimmer and headlight switches recently installed.
Another question, the headlight door switch operates with the key turned off....is this normal?
Rarely driven at night and day trips reveal no electrical problems, so not sure how long the problem existed. Car is an early 63. Any obvious solutions out there?
Joe
Joe
