correct alt number for a 69 - NCRS Discussion Boards
  • dick foehringer
    what is the correct part number for a july 69 built 427/400 with A/C? the by the numbers book is pretty vague. 1100825?
    thanks, dick
    ps also master cyl casting number? 5460346 with a MK or HK stamped on the front pad?
  • Richard G.
    • December 1, 2001
    • 107
    Re: correct alt number for a 69
    Dick
    A 69 with air or TI had a 61 amp alternator. In 69 that would be either a code 1100825 or a 1100884. For a july built car, I would look for a date code for April(G) May (H) or June (J), the numbers were pretty close to the build date. Keep in mind the NCRS rules state 6 months prior to the build date, but within a couple of months is more prevalent. If you car was a late July built car, you could even expect to see a July dated Alternator (K). An 882 was the other 61 amp alternator produced in 69, but was used on L88, L89 wTI.
    I hope this helps
    Rich
    • Dick W.
      • 10483
      Lotsa luck a findin' a 882 or 825 alternator. These were fairly low production items and Corvette only.
      Dick Whittington
        Dick and Dick-----
        Yes, the '825' is practically impossible to find with ANY date. The '882' is just about as hard to find, too. I purchased an '882' a while back for a "steal" price. It's not for sale, though.
          • 15573
          July 1969 would likely have the 884, July 1968 built 1969 would have likely have the 882. Note the use of the word "likely." Based on looking at a lot of 1969 Corvettes.
          • Mark #28455
            You can commonly get the unstamped correct style cases on e bay. Don't bother trying to stamp with your number, the font won't match! But you can at least have the correct case style for a total of about $70.
            • Richard G.
              • December 1, 2001
              • 107
              I agree, John Pirkle has them in stock so that can be helpful.
