I need to purchase new wheels for my 60. Are the repos from Coker etc, considered correct for judging purposes? What are the visible clues of a correct wheel when mounted with a tire and wheel cover?. Can anyone suggest a source. Thanks in advance for any help.
C1 Wheels
Re: C1 Wheels
Rod - I have no knowledge about what Coker sells for '60 wheels. In most judging situations, owners often get by with less than original configuration wheels because, other than the spare, they are difficult to see to judge. Standard wheels should be 5" x 15" welded construction, likely without the "dogbones". They need the 3 humps on the spider and 4 bumps on the outer rim to help retain the wheelcover. And, I hate trying to describe this, the "slots" between the spider and outer rim should be "slot" shaped, not "U" shaped. I believe you'd probably be able to acquire a real set through The Driveline.- Top
