1981 exhaust manifold hardware - NCRS Discussion Boards
  • Craig D.
    • March 1, 2001
    • 98
    Hello,
    Been a quite a long while since my last post and now a different project. On the 1981 tubular exhaust manifolds , what are correct fasteners, were they bolts only with no washers, or bolts and ring washers like prior cast manifolds had? Also, is there a gasket between the heat riser and RH manifold? The asembly manual does not show one , but looks like one would be necessary, or am I wrong? Motor was out of car when I got it and manifolds were off motor so I am starting from scratch on this one. Thanks for any input, Craig
