Does anyone know where I can get correct non-barrier A/C hose for my 67 L79? I have one section, of 13/32", but none of the rest. I have heard the barrier hose will tyically leak on the non-barrier hose barbs. At least 67 still had the clamps vs crimpted hoses.....thx!....Craig
Non Barrier A/C hoses
Re: Non Barrier A/C hoses
I was not able to locate a source of non barrier hoses.
I also heard I was going to have leaks with barrier hoses and barbed type fittings. I am currently running barrier hoses on my 66. I wanted the original look so I am using hose clamp type AC fittings. I recently took it into the AC shop where they used the special light to look for leaks. None found.
Randy- Top
Much ado....
Two years ago, I was at a high country service station. One of the mechanics inherited a '64 Buick Wildcat from his mother and brought in in for a look-see. This was the provebial 'little old lady car' that had seen disuse for roughtly 15-years before his mother passed away....
The vent caps on the A/C Schrader valves had NEVER seen a mechanic's wrench and the R-12 was tip-top in terms of pressure/fill. She blew SOLID cold air!
The notion that ALL R-12 systems will leak over time without today's 'superior' hose/seal technology is, perhaps, over-rated....- Top
What you describe is Leak Lock. Great stuff, but I would not use it on AC hoses as it sets up hard and brittle.
For AC hoses, I would use some refrigeration oil and that's it. The rubber of the hose should be enough to seal the joint. And for sealing teflon lined barrier hoses, I just slide them on dry and clamp.- Top
