Hi all,
Yet another adventure of one of the first series of tours:
Yesterday, on our second mid size tour (100 km), our goal was to visit a Heartbeat Corvette Club meeting which was orginized with the Harley Davidson club in Nederhorst (since HD is also a American brand).
Appr. 3 km before we arrived at the meeting the engine stuttered a bit but we were able to reach the meeting ground. After two hours when we decided to leave we were able to start the car but again with a bit of stuttering we drove off (with slight imberacement). Then the car drove fine for appr. 5 km when it started to stutter again, sometimes with a loud bang from the right exhaust, this time so bad that I had to stop at the nearest parking lot. When I examined the engine compartment nothing significant could be noticed. We managed to drive 2 km further but had to stop at a gas station becuase the car became undrivable in its condition.
Then we called for help (its called the Wegenwacht in overhear) which arrived in 30 minutes. He examined the carburator, arival of the fuel to the carburator, air control and ignition. He noticed a lot of oil in the coil and that it was very hot (to hot to touch) and placed an emergency coil (of a Fiat!) but this didn't solve the problem. Also the distributor contacts were checked and adjusted but this also didn't eliminate the problem. After appr. half an hour he gave up and called for a towing service which brought our car back home.
During this week I'll do an attempt to solve the problem. I guess it is a contamination of the carburator (allthough the backfires in the exhaust are a bit strange then) but also the ignition part is a clear suspect (allthough here I wouldn't expect it would start and stop stuttering like it did and also the fact that it got worse after a while is a bit strange, with ignition problems I would expect it would start and stop suddenly and not worsening over time).
Just to be on the safe side I have already ordered a new ignition coil and condensor from CC (if only to have a spare one next time we are on the road).
I'll keep you posted on the progress... Any suggestions are welcome!
greetings,
Rob.
The 1959 C1 Restoration Project
greetings,
Rob.
